Ir para o conteúdo principal
A1706 / EMC 3071—Released in November 2016, this 13" Macbook Pro introduces the OLED Touch Bar. Features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
239 Perguntas Visualizar todos
One day it just didn't turn on, how do I diagnose?
My Late 2016 13” MBP w/ Touchbar randomly decided to stop powering on. No signs of life at all. No measurable current draw when charging via any of the USB C ports. Does anyone have an idea on what I might be able to do to resurrect this hardware, or if not, how I can get at the contents of the SSD?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Well, you are in a pickle!
Sounds like the power management and/or Thunderbolt 3 controller chips have a problem. This will require someone with deeper skills to dig deeper locally.
As far as getting to your data I hope you have been good in backing up, if not you’ll need to go to someone who has the data recovery tool to gain access to your logic boards data.
Here’s more on the tool its self: This is Apple’s special tool to help customers recover data from the MacBook Pro’s non-removable SSD
Not all of the Apple Store have it and some independents managed to get their hands on them when some stores threw them away! Most just tell the customer its a lost cause and they loose there stuff as Apple will only replace the logic board not fix it.
Esta resposta foi útil?
Pontuação 1
2 comentários:
I figured as much. Thanks!
por
@mrpink86 - Sorry for the bad news, If you're set don't forget to accept the answer - Thanks!
por
Adicionar a sua resposta
Seamus será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 31
