iPhone doesn't start after battery replacement
Hi,
I replaced the iPhone 6s plus battery. I hope I did it correctly. Once I put everything back, my phone won’t turn on. I thought it’s because the battery that I received isn’t full. Hence thought of charging it.
When connected to the charger, the iPhone is stuck in the boot loop. It never starts. If the charger is disconnected then the iPhone doesn’t turn on at all (just black screen).
Not sure where the problem is - whether the connections to the chip were are wrong or the connection to the battery is wrong or something else.
I can’t test it with the older battery, as it got bent when replaced.
Esta é uma boa pergunta?
