Ir para o conteúdo principal
Smartphone projetado pela Xiaomi na linha Redmi Note.
LCD won't turned on
I just changed my LCD, at first it can turned on
But after a night the LCD is turned off, the battery is working fine, the charging light indicator is on, but the screen just can't turned on, like its not plugged in. I wonder which is the cable responsible for this cause
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Definitely try to reseat the display cable and see if there is any change. Otherwise try to see if putting the old screen back causes the picture to return, as there is the potential that you received a defective screen.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Yasub Arkan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 24
Ao todo: 309
