iPod touch solder won't melt
Using your excellent tutorial, I am on the verge of replacing the battery on my ipod touch.
The problem is the solder will not melt.
I have a Weller soldering iron with temperature control (60 Watt) so I am totally puzzled. It melts solder from my roll and I have tinned the tip.
Does Apple use different solder?
Is there some coating on it?
I appreciate your help.
Esta é uma boa pergunta?
1 comentário
Wow...dont think I've heard of this problem before. Have you tried melting solder onto the old solder (IE pretending to solder the old battery on) to help increase the heat transfer? I have to do this with some of my larger soldering jobs, it may help you.
por Phillip Takahashi
