When I switch it on It's show nothing
When I switch it on It's show nothing but if I use flesh light I see some pictures ..... I did not fix anything
Esta pergunta é pertinente?
@mphephu that mist likely means zour backlight has failed. You can replace it by disassembling your T and the LCD panel. Be careful with the sheets between the panel and the backlight strips. Make sure that you keep the the same way they are. If you give us the exact model number for your TV we can probably help you further
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 67
