Ir para o conteúdo principal
The DualShock 4 CUH-ZCT2 was announced in 2016 to replace the CUH-ZCT1 controller released in 2013. This controller is similar to the previous model.
266 Perguntas Visualizar todos
Is it possible to fix scratched circuit film?
I was checking my joystick because it drifts a little but when i open the green thing, i just accidentally scratched my circuit film, and the D-pad didn't respond when i connected it to the console.
Is it possible to fix the scratch or buy another one?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
@fixie_t you could try a scalpel to carefully scrape the covering of each off the trace then use something like a circuit writer pen to connect thos. By the time you have all those materials the cost is probably higher than replacing it. So check prices and see if you are A. comfortable with doing this and B. which is more economical/available.
Esta resposta foi útil?
Pontuação 1
4 comentários:
I think i can buy new circuit film because it’s cheaper than pen. But thanks for the answer.
por
@fixie_t makes perfect sense. Good luck with your repair.
por
@oldturkey03 i think i bought the wrong circuit film. My scratched film (as you can see on the image) is jdm-50 and the thing i bought was jdm-40(i bought it on amazon and it was just like the same as my scratched one). But i wonder if it still works if i put it on my DS4.
Then when i replaced it with the new one, all buttons actually works except R2 and L2 buttons.
por
It may or it may not. All it takes is one connection changed and it won’t function as you need it. I’d try and get the proper part for it to ensure compatibility
por
Adicionar a sua resposta
Takumi Terui será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 360
