The red light or the TV is not coming
I have a Samsung 55inc the red light or the TV is not coming on so what do I do
Esta é uma boa pergunta?
Richard Ward if you have no sign of life on your TV and if the Power Led does not turn on your TV is not getting power. Check your electrical outlet first, make sure it works. Then check the power cable and make sure it is in working order. If no results you will have to remove your TV‘s back cover. Then check the fuses on the power board and check for any damaged looking components. We will need to know your TV model number so that we can try and help you further with this. You could also post some pictures of your boards with your question so that we can see what you see.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 35
