Ir para o conteúdo principal
LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
146 Perguntas Visualizar todos
What happened to my screen?
So I have an LG, and when it dies and I turn it back on, all i get is this
the blue led is blinking and half the screen is black and the other half is just some colored pixels. (low quality pic sorry) so how do i fix this?
Esta é uma boa pergunta?
Pontuação 0
3 comentários
It appears that you have a dead screen. Have you dropped your phone without a case before this happened?
por
no it's a hand me down
por
Ah, well, You probably just need a new screen. You can find parts on iFixit and amazon.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
You will need to get the whole screen replaced more than likely. however sometime though very rarely the ribbon cable for the screen shifts off the board and you get this type of issue. either way you need to open u the phone and look and try reseating the ribbon cable. if that doesn’t work you just need a new screen and honestly the disassembly is the hardest part.
you will also need to get some double sided tape I like to use the non conductive type and you can get a set of 4 rolls of various widths from amazon.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
superiormemer será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 211
