Trigger button randomly pressing. Took the controller and pads apart
Even though i took everything (even the silicone pads apart) and cleaned everything R2 button still presses without any button attached
Esta pergunta é pertinente?
Once you open your controller and take out the motherboard, you can see the flat cable that all buttons are connected to. Make sure that the contacts are fully clean, both on the cable and the motherboard itself. Use some rubbing alcohol(isopropyl alcohol or so) to clean it, as water may damage other components.
If that doesn't work, you could try to replace the flat cable and see if that works.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 31
