Ir para o conteúdo principal
The Olympus OM-D E M10 Mark II is a 16 megapixel mirrorless camera that was introduced in 2015. This camera can interchange lenses with its easy to use platform that is both user friendly and priced for amateur photographers without lacking professional capabilities.
4 Perguntas Visualizar todos
Camera not powering on
Display was not working fine so I have replaced flex cable. Right now the camera is not powering on but there is a light on front that is flashing. I have also measured voltage on mother board across flex cable from display and I am reading 2.9v max. Do I have to replace the entire motherboard?
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Why did you think the display needed replacing? Did you bang or get your camera wet?
por
The display was flashing during tilting
por
Adicionar um comentário
1 resposta
What happens if you disconnect the display cable from the logic board? Does the eyepiece display still work?
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Vitt será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 256
