Ir para o conteúdo principal
Samsung un55ks8000 turns on but black/gray image power light blinks 7
My Samsung un55ks8000fxzc started having this problem where when I turn on the tv all I see is a grayed out image and the red power lights stays blinking 7 times. Then it power cycles and keeps repeating the same steps.
Any idea what it could be?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
So I was able to get the TV to turn on and return to working order by taping 3 of the lines on the ribbon cable inside the TV. I followed instructions on a video online. Right now everything is working but I just want to know if this fix will stay and if there is something more permanent like replacing a part which I can do . Any info would be appreciated
Esta resposta foi útil?
Pontuação 0
2 comentários:
@godfather17 which video did you check so that we can see what lines you taped....?
por
There are several videos online. One in English and one in Spanish
por
Adicionar a sua resposta
Godfather17 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 78
