Ir para o conteúdo principal
How to fix broken ram slot
One of the two ram slots broke, is there a way to fix it
Esta pergunta é pertinente?
Pontuação 0
Comentários:
@danj do you have any idea?
por
What broke? Post some pics so we can see Adding images to an existing question
Most of the time there is little you can do as the frame is well anchored. You would need to replace the frame which is not easy and the cost would be more than replacing the logic board. If the latches are damaged you can try wedging some plastic to hold the needed pressure on the SO-DIMM.
por
@danj its not the frame or latches,
Its the slot, a picture wouldn't be very useful,
The problem is inside the slot
por
@beanman56 - New frame then, I would just replace the logic board at this point MacBook Pro 13" Unibody (Mid 2010) 2.4 GHz Logic Board
por
:| don't want it THAT much,
But thanks again @danj
por
Mostrar mais 1 comentário
Adicionar um comentário
1 Resposta
There is. but your not going to like it. but contact Louis Rossmann of Louis Rossmann group in NY New York. he may be able to repair it. https://www.rossmanngroup.com/
Esta resposta foi útil?
Pontuação 0
Comentários:
por
Adicionar a sua resposta
BeanMan56 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 17
