Ir para o conteúdo principal
Where can I get some airport and speaker screws?
I fixit doesn’t have any,
I NEED THEM TO FIX MY MAC
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
Solução escolhida
you need a friend that has a thread gauges and a caliper measuring device. he will tell you it is a M(#) or what the tread and shaft size is. most local hardware stores can get them. If you can’t find locally McMaster will surely have them.
Esta resposta foi útil?
Pontuação 1
Comentários:
i dont have the screws though
por
@beanman56 I am guessing the speaker ones are M2x3.8 and M2x5. the translating for the first one is M2x4mm
https://www.amazon.com/Stainless-Phillip...
por
@beanman56 actually this set is better for you needs. except it has limited M2 ones. the other kit has more M2 types.
https://www.amazon.com/QTEATAK-300Pcs-No...
por
its on the left side,
also does the does the set it include:
Two 8 mm Phillips screws
One 4mm Phillips screw?
por
Mostrar mais 2 comentários
Adicionar a sua resposta
BeanMan56 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 5
