Is it have MDM like Jamf or Apple Business Manager? If it does, that’s a setting that can be enabled. On a normal Mac me or you would buy retail (which will not be managed, it’s added after the fact) the account will not lock this way - M1 might stop you for 5 minutes and go up until you have to on an M1 but Intel Macs permit unlimited chances. If you see “profiles” in System Preferences, then it’s managed. If nothing works, the password needs to be reset by IT - especially with MDM. I mention this because you said you work for a school district. A lot of MDM solutions “escrow” the FileVault key, so you need to call for this 99% of the time.
If it isn’t managed or all else fails, use Terminal:
Apple silicon:
- Press and hold the power button until you see the startup options
- Click Options. Let the Mac boot - no intervention is needed.
- The Mac will ask for a known user account that's an admin. If you know none select forgot all passwords.
- It may ask for an Apple ID. Any good MDM allows you to force sign out and remove activation lock if needed. Hopefully it was blocked.
- Click on Utilities at the top bar and find Terminal
- Enter resetpassword and press Return
- If required enter the FileVault key. Again any good MDM “escrows” this.
- Reset the password and the machine should be good to go.
- NOTE: You may have to reset the user’s password as well. Make it easy and force a reset in Jamf before handing it back.
Intel: - Shut down the Mac and press Commnd+R together before turning the system on, and then press and release the power button. Keep holding until you see MacOS Recovery start.
- If it asks for an admin, select Forgot all passwords. T2 Macs can activation lock, but they tend to go to the utility options - but yes, it can sometimes be an issue here as well.
- Click on Utilities at the top bar and find Terminal.
2 comentários
i have the same problem. i tried to go to recovery but its not working. i cant open terminal or any. i shuted down and held command + R but nothing happened. i dont know what to do.
por Amh Sh
@Amh Sh If this is an M1 machine, you need to press and hold power to access recovery options rather than the old cmd+R
por Alisha C
