2010 MacBook Air Throttling when battery half empty
For some reason, my Macbook Air is throttling and not running at full performance when the battery level is under 40 ish percent. I have iStats Menu and it seems like the CPU is peaking around 140 degrees compared to the 180-190 that I normally get when I use my computer at full load at battery percentages above 40. And the fans never spin up as well. And when the battery gets under 20 percent, the temperatures max out at 120 and the fans never spin up either. And the computer runs much slower and the lag gets worse. However, the moment I plug in my computer, the lag stops immediately and then the temperatures go back up to 180-190 like usual and the fans spin up.
I thought it was a battery issue because sometimes I would get a "service battery" message that occasionally goes away. I replaced the battery but I am still experiencing the same issue. Is this normal behavior or do I need to get another battery replacement? I know that macs tend to throttle when the battery is removed.
Esta é uma boa pergunta?
9 comentários
Install this and take a screenshot of the battery specs and upload it
coconutBattery 3.9.6 - by coconut-flavour.comhttp://coconut-flavour.com
por Ben Capehart
@beanman56 Just added it. Other sources indicate that it's the battery even though it's at full health.
por jimmysofat6864
hmmmmmmmmmm no other ideas,
sorry :/
por Ben Capehart
Lets take a look at Activity Monitor, you'll find the App in your Utilities folder in the Apps folder. Look for kernel_task under % CPU what does it show for percentage?
por Dan
@danj Sometimes it goes up to 25 or hangs at high usage but it goes back down to normal levels so I don't think that's the problem.
por jimmysofat6864
Exibir mais 4 comentários
