Ir para o conteúdo principal
Um console de videogame para TV produzido pela Sony Computer Entertainment; o PlayStation 4 Slim (CUH-2000 Series) é o modelo sucessor do PS4 original. Data de anúncio: 7 de setembro de 2016.
400 Perguntas Visualizar todos
PlayStation 4 doesn’t work on some TVs
The PlayStation 4 we have registers as a PlayStation on our TV, but doesn’t show any video. It does work on another small Samsung TV though. We are so confused, can someone help? The port works with other devices, the cable works with other devices and other TV’s, and the PlayStation just doesn’t show video.
Esta pergunta é pertinente?
Pontuação 0
Comentários:
Hi @mbryant12 ,
What is the model number of the TV?
por
Adicionar um comentário
2 respostas
If it’s an old TV I wonder if it lacks HDCP or something similar.
Esta resposta foi útil?
Pontuação 0
Press and hold the power button on your PS4 for seven seconds.
 This ensures that the PS4 really turns off, which is necessary for starting it in Safe Mode. ^^^^You will hear one beep when you begin to press and hold the button, and a second after about seven seconds. You can remove your finger from the button after you hear the second beep.
  • If you're seeing "No Signal," "Weak Signal," or a blank screen, it could be because the resolution is incorrect in your PS4 settings. This sometimes happens when you move the PS4 between different TVs, switch between game systems on the same TV, or make a change to your TV's display settings.
Pontuação 0
Adicionar a sua resposta
Mason B será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 22
