Ir para o conteúdo principal
Fones de ouvido da Apple com um conector Lightning em vez de uma entrada para fone de ouvido de 3,5 mm. Compatíveis com iPhones desde o iPhone 7, não compatíveis com MacBooks. Lançados em 2016. Identificáveis pelo número de modelo MMTN2AM/A (Branco).
Replacing/Repairing the Lightning port of the EarPods.
I couldn’t have described my problem anywhere else, as I was getting bizarre results for my searches.
The problem that I am facing is that the small metal piece(The part that goes inside the phone while charging) on the lightning cable broke and I don’t know what to do, I browsed how can I repair the jack or something like that, but the repairing involved some serious precision work(Clipping/precise soldering) and I don’t want to follow that currently, Meanwhile a thought came to my mind, but I’m not sure if it is even going to work or not?
I was thinking that instead of scrapping the plastic out and carry on with the soldering stuff, what I can do is maybe take a lightning charger cable(Official/alternate)… Chop it off and then connect the wires with my Earpods.
I wanted to know if it is going to work? If yes, then will I be able to get all the features intact? Like using Mic, Controlling volume up and down? Don’t lose the quality of music on my Earpods?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
No, soldering a lightning cable to the earpods will not work. This is because there is a DAC in the lightning connector of the EarPods that is not in a normal lightning cable.
What you need to to is to buy a 3.5mm to lightning adapter and chop the 3.5mm end off.
Esta resposta foi útil?
Pontuação 1
2 comentários:
@andrewsawesome So what else can I do?
I do have another idea, but I'm not sure if it is going to work or not, What if I buy a 3.5mm Aux TO Lightning Connecter? and then I chop it off and use that end(Lightning End) with my Earpods? Will that suffice?
por Compartilhar
@AgrsIV・AmMÓ That would work(chopping the 3.5mm end off a 3.5mm to Lightning adapter).
por Compartilhar
Adicionar a sua resposta
AgrsIV・AmMÓ será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 63
Ao todo: 2,339
