iPhone X slightly bent, Solder two layers together
How do I solder two layers back together when the top layer is slightly bent at the top?
Thanks in advance!
Esta é uma boa pergunta?
Thanks in advance!
If it is the front of the board that isn’t connecting I wouldn’t be too worried as they are all ground pads. If it is bent significantly you will need to solder the spacers back on and clamp it down while heating.
I think there are about 8 spacers. You might have to get them from an unseparated IC board if you haven’t saved any from the other boards.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 50
1 comentário
@iammyron07 two layers of what? Has the screen separated or the logic board? Give us more detail
por oldturkey03
