Ir para o conteúdo principal
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
554 Perguntas Visualizar todos
Built-in speakers and headphone jack work wierd
Hello! Built-in speakers in my macbook work only when I plug in the 3.5mm headphone jack (with no sound in the headphones as I plug them in). As soon as I pull it out, I have no sound from the built-in speakers as well. Its like an inversion - only when headphones are plugged, built-in speakers work. I have replased the 3.5 mm port in my mac for a new one, but it did not help. What could it be?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Surprisingly your problem is within the main logic board!
I’m suspecting you had a liquid spill at some point which has damaged your audio CODIC chip which is just on the other side of the logic board.
You’ll need to remove the logic board to inspect it and clean up any corrosion it has. Follow this guide MacBook Pro 15" Retina Display Mid 2012 Logic Board Replacement Look at the Cirrus labeled chip area.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Dimitri será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 13
