Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1863, A1905. Disponível com GSM ou CDMA / 64 ou 256 GB / Dourado, Prateado e Cinza Espacial.
872 Perguntas Visualizar todos
Home button too sensitive
Got an 8 with a too sensitive home button, replace turtle but still its the same… any ideas why?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
the 7/8/SE (2nd gen) home buttons are not mechanical, like those in the 4/5/6/6s, and really don't have a "sensitivity" that can be adjusted. that said, i have found that loosening or tightening the screw that holds the actual button to the home button display bracket can change how the button responds to a touch.
on a side note, did you DIY the Turtle IC replacement? if not, can you tell me who did it, if it's a commercial service with a website?
also, did replacing the Turtle IC make the Touch ID stop working? or is the home-button-to-motherboard pairing for Touch ID not rely on the Turtle IC chip?
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Myron. será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 59
