Ir para o conteúdo principal
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Perguntas Visualizar todos
The ram isn’t detected in slot 0
No matter what I try, I cant get any ram to read to read from slot0. BUT, It does read from slot1. I got it 2nd hand as working, but when I got it, it beeped at me. I swapped the original ram into slot1, and it worked.
Would this be a MoBo issue, or something else? Any help is appreciated.
Thanks, Soup
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
What is the specs of the SO-DIMM's you bought?
This series can only support a max of 6.0 GB so will encounter issues if you try to install 8 GB of RAM (two 4 GB SO-DIMMs).
Try one 4.0 GB SO-DIMM alone in Slot-0 did that work? Then put in one 2.0 GB SO-DIMM in Slot-1
Esta resposta foi útil?
Pontuação 0
3 comentários:
I only have two 1gb sticks and one 2gb stick. All of them work in slot1, none work in slot0.
I bought the 2gb IFixit ram for this iMac.
por
@soup244 - Well, I guess you'll need to get a 4 GB SO-DIMM and just live with the single socket.
por
Yeah, guess you’re right. Thanks.
por
Adicionar a sua resposta
Soup será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 29
