Ir para o conteúdo principal
Released in May 2020, the 13" MacBook Pro features quad-core Intel 10th generation Core i5 and i7 processors, and Intel Iris Plus integrated graphics. (Model A2251/EMC3348 with four Thunderbolt 3 ports)
54 Perguntas Visualizar todos
How to recover data from SSD from MacBook that won't turn on
I recently spilt a latte on my MacBook Pro and it will not turn on. I think the SSD is undamaged however. How can I get the data off of this if the computer itself won’t turn on? It is possible to remove it from the enclosure and put it in to something else?
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
Solução escolhida
You can’t ;-{
This series storage is soldered directly to the logic board as you can see here:
The Green chips are the SSD chips, the T2 chip (Orange) also encrypts using a bunch of data scattered on the logic board so you can’t get to the data so even if you could desoldered chips you couldn’t use them in another system
Esta resposta foi útil?
Pontuação 4
2 comentários:
So the data on SSD is encrypted? As far as the logic board wouldn't work, I can discard the logic board with the SSD and don't need to worry about data safety?
por
@Kuro Kurosaka - I would still cut the board and physically damage the flash chips (at least one) to be sure as tech is constantly getting better!
por
Adicionar a sua resposta
Jacob Robinson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 137
