Ir para o conteúdo principal
O iPhone 5C da Apple foi lançado em 10 de Setembro de 2013. O reparo deste smartphone é similar aos modelos anteriores. Você precisará de chaves de Fenda/Philips/Torx 0.8 e espátulas de plástico. Disponível nas versões GSM ou CDMA / 8, 16, 32 GB / Branco, Rosa, Amarelo, Azul e Verde.
1233 Perguntas Visualizar todos
Why won’t my phone turn on?
Hi,
I have an iPhone 5C.
I plugged the phone in, the screen lit up for about a second, and then it turned black.
I tried to force restart it, but it didn’t turn on.
I thought it was a battery issue, so I opened it up, but the battery appeared fine.
I unplugged the battery, and it still wouldn’t work.
When I turned it on, the Apple logo didn’t appear, it might be a screen/graphics issue?
I’m not sure what the faulty part is.
I’ve got data on it that I want to recover.
Any suggestions?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
You cannot tell if the battery is bad by its looks. The first thing to do is see if iTunes recognises it.
·         If it does you most likely need a screen replacement.
·          If it doesn’t you will need to replace the battery.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Anonymous será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 48
