Ir para o conteúdo principal
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Perguntas Visualizar todos
Difference between PC2-6400 and PC2-6400S
Hello,
I want to upgrade the RAM on my iMac 20' early 2008.
According to Mactracker, I need 200-pin PC2-6400 (800MHz) DDR2 SO-DIMM.
I found PC2-6400S, is there any difference ?
Thanks
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
Solução escolhida
The S at the end usually denotes it is SO-DIMM, for laptops, though not always used. With more people buying online, not physically being able to examine the product, it helps people know what they are buying. The use of the "s" at the end is becoming more common to denote it is laptop memory.
Esta resposta foi útil?
Pontuação 6
1 comentário:
Thanks mate!
por
Adicionar a sua resposta
Ben será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 28
Duração total: 30,196
