Ir para o conteúdo principal
Modelo A1502 / processador 2,4, 2,6 ou 2,8 GHz de dois núcleos / Lançado em outubro de 2013
552 Perguntas Visualizar todos
Battery not charging, magsafe 2 light not showing
Hi,
The computer's battery is not charging, as described in the picture:
The magsafe connector has no light indicating its operation.
I used another connector to test if the problem was in the cable, which is not the case, the other connector also had no light, and in the same way as the previous one I could make the computer work but not charge the battery.
The battery is new, I changed it after I got a message that the old battery needed to be changed. I don't remember exactly, but I am pretty sure that before I changed the battery this problem already existed.
Sometimes, especially when the computer is warm, the connector lights come back on and the computer battery charges normally. This makes me believe that I probably have a hardware problem.
Coconut battery picture for reference:
Any idea what the problem might be?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Often the contacts and insulator area is dirty
Make sure your’s look like the bottom one in this image
Otherwise the MacBook Pro 13" Retina (Late 2013-Early 2015) MagSafe 2 DC-In Board maybe bad. I would also inspect the logic board connections from the DC-In Board our corrosion on the middle contact as thats the one wire comm link to the charger. Here’s the guide Substituição da placa de energia CC MagSafe do MacBook Pro 13" com tela Retina Final 2013
Imagem de MacBook Pro 13" Retina (Late 2013-Early 2015) MagSafe 2 DC-In Board
Produto
$14.99
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Mike será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 76
