Ir para o conteúdo principal
A2115 / 2019 / Processors from 3.0 GHz 6-core i5, up to 3.6 GHz 8-core i9. Released March 19, 2019.
Replacing 2019 LCD panel with and older 2017 LCD panel
I am wondering if it is possible to replace a 2019 27” lcd screen with an older 2017 model? will it work without any special configuring? Are all the connectors the same? I know there is a difference technically in the performance although very hard to tell by eye.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
They are the same mechanically, the Gamma and Brightness are different. If you don’t care about color or brightness it will work.
Esta resposta foi útil?
Pontuação 2
1 comentário:
I replaced the 2019 iMac 27 lcd with one from a 2015, both 5k, and working fine excepting gamma and brightness not quite the same but fine for my purposes.
por
Adicionar a sua resposta
ledpestol será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 99
