Ir para o conteúdo principal
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
398 Perguntas Visualizar todos
Can I add a logic board with a GPU?
Can I add a 2014 MBP logic board with a discrete GPU to a 2014 15” MBP that only has integrated graphics? or is the frame and or screw holes different?
Esta pergunta é pertinente?
Pontuação 0
Comentários:
Has your GPU failed?
por
Adicionar um comentário
1 Resposta
Solução escolhida
The IG and DG models are very similar! So you could swap out your IG logic board with a DG board but you will also need a new heat sink.
Now the bad news ;-{ I think you’ll find a used system for less! Check eBay
Here’s a price list for reference: Mid 2014 15” MacBook Pro Logic Boards
Here’s the guide MacBook Pro 15" Retina Display Mid 2014 Logic Board Replacement
Esta resposta foi útil?
Pontuação 1
Comentários:
Yikes, those prices aren't pretty. Thank you for your help!
por
Adicionar a sua resposta
Evan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 18
