Which product kit I should buy to fix the ipad mini4 digitizer
I only find the kit for ipad mini 1/2 on the store, will it work with my ipad mini4?
Esta é uma boa pergunta?
Unfortunately the iPad mini 4 uses different components for the display and digitizer than the mini 1 and 2. The iPad mini 1 and 2 use a separate LCD and digitizer while the mini 4 uses a design that fuses both parts together into one display assembly. If you need to replace the digitizer, you will need to replace both pieces as one unit.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 37
