Ir para o conteúdo principal
Repair and disassembly information for Samsung's flagship S20+ Android smartphone, released in March of 2020.
After changing lcd, camera function didn't work
I changed lcd my s20 plus and also I replaced old original camera, but still didn't work. If I clean the the cache memory and clean all setting from app>camera>storage>clean cache, then the all backs camera works. but when I switch front camera then it hang and still on blurry back camera. and then I open again camera app, only black display appear. and clean cache work back camera again.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Can you check the part number on the replacement camera part to see if is the same as the original part? In my experience, using a genuine Samsung part can still cause issues exactly as you’re describing(hanging when switching cameras/only showing black screen) unless it’s the same part number.
Only the exact same part number replacement part will work for full functionality.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Asaduzzaman Rupu será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 271
