Ir para o conteúdo principal
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
20 Perguntas Visualizar todos
iPod won't turn off
A number of years ago I connected my iPod classic 80gb to a docking speaker and upon doing so it made a popping noise like static almost. Ever since then the iPod won’t turn off, I think its a problem with the connector inside the iPod, like the connectionists bent or something. The device charges and works fine as long as I have the battery charged, it also maintains a charge, but again it is like its always on. I can restart the device with no problem. nothing wrong with the screen but it runs the battery dead because it won’t turn off. Currently I have it in my vehicle on a USB port that only works with the car is on so everyday it has to charge again before I can use. Any help would be appreciated.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Does the iPod turn off if you press & hold the play/pause button for a few seconds?
You can also go to Settings > Main Menu and select Sleep. This will add a sleep button to the main menu.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Stout Germ será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 314
