Ir para o conteúdo principal
Announced on October 16, 2014, the iPad Air 2 is a thinner successor to the iPad Air.
448 Perguntas Visualizar todos
iPad Air 2 backlight spots
Have a issue with iPad Air backlight. It has spotlights and Ive tried a new diode, new filter but its the same. I will attach pictures if possible
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Myron, Myron, Myron…
you've been in it for so long, you shouldn't have any problems with the basic methods of mictoelectronics diagnostics. Take a multimeter and check the voltage and resistance values of the backlight power channels. Don't forget about continuity of logical lines. Finally (if not electronics), it may turn out that the LEDs on the screen have turned off (maybe due to previous experience or simply because of a damaged connector). Change a screen assy for test.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Myron. será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 32
