Ir para o conteúdo principal
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
304 Perguntas Visualizar todos
Xbox one S LB button hard press issue
Hi, I want help in fixing my Xbox One S controller’s LB button. The LB button is fine but whenever i try to press it quickly i mean light clicking so it won’t respond but when i try the hard clicking so it wil respond.
Please help me in fixing this.
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
You are probably going to have to go into the controller and clean the button contact. Use isopropyl alcohol and a q-tip. While you are in there, you might just want to clean the rest of them to avoid further issues. If this doesn’t work, you probably have a defective button and will have to replace it. It sucks, but it happens, I had to once on a DSi.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jahanzaib Khan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 9
