doesn't power up nor can it charge
my 2018 13 inch Retina display MacBookPro doesn’t power up and doesn’t charge. I tried SMC reset as well as as PrAM/NVrAM reset but they all failed to power up. is there another fix I can try before I bring it to a fixit shop?
Esta é uma boa pergunta?
Does your charger have a LED on it when plugged in? If so what the colour of the LED. If not, possible the IO Logic Board (The smaller separate logic board) has damage or even a main logic board issue. It could also be a bad battery, which would be the better issue to have.
por Jon Williams
@eazy_pc_repairs - Jon - This series uses a USB-C charger which doesn't offer a charging LED. Really need a USB-C power meter to give you the info on your charger and battery.
por Dan
@danj Sorry about that, I did not think :D Voltmeters are relatively inexpensive (£20 or so) though so OP you should be able to get one quick enough and let us know your findings, Amps draw will tell us a lot about whether its dead or trying to turn on or partly booting :)
Let us know if you decide to get one and let us know. I know my amp lighting cable for iPhones is a huge help :)
Good luck Sir
por Jon Williams
