Ir para o conteúdo principal
My phone Volume is acting weird
So, I don’t know why but every time I press the button to turn my volume up it goes all the way up. It started doing this recently tonight and I have no idea why or how it’s doing it. I’ve tried turning my phone off and on again to no avail. I even see the volume bar turn up. I have also tried looking this problem up but with no luck. I feel like I might be the only one who has this issue. My iPhone says it’s an iPhone Se (?). I took off the case and that’s what it said. Anyway, I hope I can get some help because I don’t know what is happening.
Esta pergunta é pertinente?
Pontuação 0
Comentários:
Double check to make sure there's no grit or grime in the volume button, lots can build up in there an cause it to stick. It should make a nice clean click feeling when you press it
por
have you spilled any sticky liquid on it? it honestly sounds like something its jamming the button.
or maybe part of the case is jutted out and jamming the button down?
por
Adicionar um comentário
1 Resposta
hello Belle,
you probably have a broken switch inside the case. Maybe because of wetness or sand from the beach. Temporarily, you can change the volume in the "control center" but the component responsible for changing the volume (flexible tape with several switches and sensors) will have to be replaced sometime. A new tape costs $ 0.90, while a replacement - if you can't do it yourself, check in your area.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Belle Kross será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 14
