Why won't the blades ingage
The switch won't engage the blades
Esta é uma boa pergunta?
Potential reasons:
* Has your battery got full charge? A weak charge can keep the blades from engaging.
* Is your belt stretched too tight, worn-out or damaged? That can cause the belt to snap out of position.
* Is your drive belt which is under the seat, okay . . . because it engages and disengages the mower blade.
* Is your clutch working? Your riding mower blades won’t engage if the clutches are broken or the cable is damaged.
* Is your deck belt damaged? This can freeze the pulley system.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 18
