Best possible cpu upgrade with board change?
Current: Core 2 Duo (E7600) A1312 (EMC 2309) LGA 775 Socket T.
Can I swap the board with any of the LGA 1156 Socket H boards?
Esta é uma boa pergunta?
You’re in luck! No need to replace the logic board only the CPU.
This series is a transition series. Intel offered their first i5 & i7 series chips as direct drop-in’s: 27” iMac Processor Chip - 2.8GHz i7, Apple P/N 661-5428
Esta resposta foi útil?
I appreciate the reply.
The CPU you linked is for an LGA 1156 socket and will not fit the LGA 775 socket.
If I'm overlooking something, please inform me as I'm willing to learn :)
@realrobd - OK, It is the correct chip, but here's the full logic board 27" iMac Logic Board 2.8GHz i7, Apple P/N 661-5428
So the i7 860 will drop right in?
Will there be firmware issues to contend with?
I found this: Core Duo 2 to i7 in Late 2009 iMac?
@realrobd - Yep! As I stated:
"This series is a transition series. Intel offered their first i5 & i7 series chips as direct drop-in"
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 221
