Ir para o conteúdo principal
Lançado em junho de 2012, modelo A1278. Processador Intel com Turbo Boost, até 512 MB DDR5 de RAM vídeo
1623 Perguntas Visualizar todos
New drive and I dont have recovery because the old drive broken
I use macbook pro A1278, my old drive was broken and i get a new hard drive. Then i wanna install macOs on it using USB…but when i switch on the macbook and press option button , the screen show folder with questionmark ..how do i need to do? Seem like cant install macOs
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Did you press the option button or hold the option button?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Do you have a friend with a Mac that can help you create the needed USB Thumb drive OS installer?
First you’ll need to have him download the OS you want to use. I would recommend either sticking with macOS Sierra 10.12.x or jump to macOS Mojave 10.14.x. Sierra still uses the older HFS+ file system, whereas Mojave used the newer APFS file system. SATA based systems do better with HFS+ which is why I recommend using it, High Sierra is a bit messy which is why going to Mojave is the next choice. While your system can support Catalina 10.15.x you’ll loose access to older 32bit apps. So here’s the site to get the OS’s How to get old versions of macOS.
You’ll need to format the USB thumb drive using Disk Utility to GUID and a Journaled file system before you start, then follow this guide How to create a bootable macOS Sierra installer drive or How to create a bootable macOS Mojave installer drive. Once you have the working installer you should be able to boot up under it and prep your drive.
If you still are having issues this series did have issues with the HD SATA cable, you may need to replace it MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable and here’s the guide MacBook Pro 13" Unibody Mid 2012 Hard Drive Cable Replacement and bit more on the issue Your Hard Drive Cable Is A Ticking Time Bomb I would also place the tape down as well.
Imagem de MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
Produto
$34.99
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Hafizxi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 24
