Ir para o conteúdo principal
Model A1046 or A1095 / 1280x854 screen resolution
118 Perguntas Visualizar todos
dropped laptop now screen doesn't work
PowerBook g4 i dropped laptop now screen doesn't work
UPDATE:
the hinge still works properly. my PowerBooks stll boots up and it sounds like the hardrive is spinning. the screen just stays black.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Please be more specific about the PB damages (hinges OK ?) and what's happening when you push the power button. Any activity ? Do you hear the boot chime ? Do you hear the hard drive spinning ? Check if you see a faint image of the desktop if the machine boots.
Esta resposta foi útil?
Pontuação 2
3 comentários:
Hinges ok, it's booting up and it sounds like the hardrive is spinning but the screen stays black.
por
I also tried connecting to a external monitor and it didn't work.
por
That's bad news. No external video signal could be related to a logic board damage. Well try all the usual troubleshooting stuff like the pram reset, PMU reset, boot from the installation disk, etc. Any damage to the PB case ?
por
Adicionar a sua resposta
todd será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 935
