My iPhone 6s won't charge
Whenever I try to charge my Iphone 6s it will not charge, I recently received a iFixit pro tech tool kit. I am wondering what part I will need to replace to fix it.
Esta é uma boa pergunta?
The steps to diagnose this issue would be to replace.
1. Charging cable.
2. Battery.
3. Charging dock assembly.
If it still doesn’t charge it will most likely be one of your charging IC’s the most common to fail on the 6s is the Tristar IC. Unfortunately you will need more equipment and experience than the ifixit tool kit as microsoldering is required.
Esta resposta foi útil?
And just to ad what Jon Williams said here, simply cleaning out the charging port with some tweezers or similar tool to remove dust/lint buildup may save you replacing parts in the device unnecessarily.
@smashedliam Exactly cannot count how many devices i have saved with a simple cleanout.
Have you tried using a pin and scraping the bottom of the charger port. 90% of charging issues tend to be caused by lint build-up In the base of the charging port. Using a good light you should be able to see all the debris. Try not to scrape at the contact pins in the side, just go right to the bottom of the port, scrape from side to side and try to hook any loose bits out of the port, Compressed air can help you once you have loosened any dirt, etc.
Likely, the problem you are experiencing is caused by a faulty (old) battery. However, it is possible that your charging port is broken. Try charging the phone wirelessly. If the phone cannot be charged through the charging port OR the wireless charging feature, the battery is the most likely culprit. However, if the phone can charge wirelessly, you would need to replace the charging port.
iPhone 6s do not contain wireless charging, iPhone 8 was the first to feature wireless charging. Also, there are many things to try before simply replacing the parts :)
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 31
Duração total: 240
