Ir para o conteúdo principal
The Lenovo ThinkPad X1 Extreme (Gen 1) is a high-end multimedia laptop designed and manufactured by Lenovo. It was released in 2018 and is identified by the model number 20MF-000LUS.
4 Perguntas Visualizar todos
Lenovo Thinkpad Tablet not turning on
My tablet started having this issue where it won't turn on today. It was working fine yesterday, but when I tried turning it on this morning, it wouldn't. I've tried the plug in and press power button for 20 seconds then unplug and press power button for another 20 seconds, but that didn't work.
I have artwork on my tablet so I would much prefer if I didn't do a factory reset since none of it is stored on my SD card.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
If you already tried a hard reboot of the tablet, then the problem may be the battery. Try removing your battery for about 10 minutes, and then put it back in. Try charging the tablet with a different USB cord or electrical outlet. If that doesn't work, there are battery replacement instructions at the following link:
Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement
Esta resposta foi útil?
Pontuação 3
1 comentário:
It worked! Thank you so much! Though I got the model wrong. It's a Lenovo Thinkpad X1 Tablet
por
Holding the power and both volume buttons down on my X1 brought it back to life.
Pontuação 0
Adicionar a sua resposta
Kit será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 35
Duração total: 4,969
