How come my battery capacity is less than 100%
I only have 5 cycles on this battery, but it’s showing a 94% capacity already. Please see attached photo
Esta é uma boa pergunta?
Your laptop says it is from 2015, and I’m assuming that the laptop wasn’t kept charged from it manufacture date until now. Likely, the battery cells have degraded a bit. You could replace the battery yourself, use the laptop anyway(and change the battery later if you need), or contact Apple if they sold you the device.
Esta resposta foi útil?
This is a brand new battery I fix it just sent me.
You should contact iFixit support then.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 19
Lets get a newer version of CoconutBattery as this one is quite old! The current release is 3.9.5. Here's Coconut-Flavour web site to get it CoconutBattery You'll still want to check the version info as well as the download I think is one release back.
Then post a fresh snapshot of the full window with the battery info opened as well.
por Dan
