Ir para o conteúdo principal
Repair guides and disassembly information for Apple's 8th generation iPad. Released September 18, 2020. Model numbers: A2270, A2428, A2429, and A2430.
34 Perguntas Visualizar todos
I can't see an iPad 8th gen replacement digitiser replacement kit?
I can’t see an option for an iPad 8th gen digitiser on the store, can you help? I want a good quality replacement part or if not available, which tool kit is ideal for the replacement of the digitiser? Thanks!
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Pergunta mais útil
You’ll want to order the Pro Tech toolkit as it will have everything you’ll need and more to fix your iPad and other devices if need be. Pro Tech Toolkit
You can find replacement screens for the 8th gen on either Mobile Sentrix, Injured Gadgets, or Mobile Defenders. Mind you it’s just the parts you’re buying from them and they’re the top 3 parts suppliers and they back their parts with a solid warranty. Just create an account and order what you need!
Imagem de Pro Tech Toolkit
Produto
Pro Tech Toolkit
$74.99
Esta resposta foi útil?
Pontuação 1
iPad 7 screens are the same as iPad8 screens, most vendors will sell them seperately but if you can find an ipad8 screen then order one for an ipad 7
Pontuação 0
Adicionar a sua resposta
Noah Derrington será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 33
Duração total: 3,158
