Ir para o conteúdo principal
Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Perguntas Visualizar todos
Failure to boot after re-applying thermal paste
Hello,
my late 2011 MacBook Pro won’t boot. Shortly after displaying the Apple logo, it has the grey/black spiral and approximately at 70 % it’s going on forever. This problem appeared after I took apart the Macbook to apply thermal paste using this guide:
MacBook Pro (13 Zoll, Ende 2011, Unibody) Kühlkörper austauschen
The Safe Mode is working slowly and so far there is no sound. What can I do or have somebody an Idea or solution?
thanks in advance!
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
This sounds like too much thermal paste!
Go back in and take the heat sink off, take some picks so we can see things both the chips and the heatsink side and post them here for us to see Adicionar imagens a uma pergunta já existente
por
Adicionar um comentário
2 respostas
Try resetting NVRAM/PRAM. First, turn off your Mac then follow these steps:
  1. Press the power button.
  2. Immediately press the Command+Option+P+R keys.
  3. Hold the keys until your Mac restarts and you hear the startup sound, keep holding till you hear the startup sound a second time.
  4. Release the keys.
You could also try an SMC reset:
If the battery is removable:
  1. Turn off your Mac.
  2. Remove the battery.
  3. Press the power button and hold it for a few seconds.
  4. Reinstall the battery.
  5. Press the power button to turn on your Mac.
If the battery is non-removable:
  1. Shut down your Mac.
  2. Press Shift+Control+Option on your keyboard and press the power button at the same time.
  3. Hold these keys for 10 seconds.
  5. Press the power button again to turn on your Mac.
Other than the above, make sure all your cables are connected and fully seated, make sure all the screws are in their correct holes, so you do not cause damage by putting a long screw in a small hole :(
Hope this helps :)
Esta resposta foi útil?
Pontuação 0
2 comentários:
Thank you very much. The battery is removable. I tried both reset but no Change.
por
I would then follow @danj advice as it would be the next logical step.
por
@nobert - Yep, you over did the paste! You'll need to clean it all off. sadly its going to take a bit more than wiping off as you’ve got it over the small SMD devices that are also on the green chip carrier. Using a soft tooth brush and 90% isopropyl alcohol carefully clean off the caught paste around the SMD components. Use extreme care as you don’t want to lift any of them off which is quite easy!
Clean the heat sink as well asd then use one quarter of what you used! It’s not the quantity it’s the placement and not over doing it thats important only getting it on the Black silicon chip.
Pontuação 0
Adicionar a sua resposta
Norbert Power será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 731
