Ir para o conteúdo principal
Despertador Philips Wake-Up Light com simulação de nascer do sol colorida, cinco sons naturais e rádio. Lançado em abril de 2017. Número do modelo: HF3520/60.
device "clicking" quickly like proximity sensor feels something
Philips HF3520/01 Wake-Up Light - suddenly starts making never-ending quick “clicking“ sounds, speeding up.. This is normally sound of proximity (touch) sensor.. but there is nothing close to device, and it is clean…. It is unstoppable, only it stops if disconnected from power… After connecting it can work for hours correctly, but problem appears later again…
Esta é uma boa pergunta?
Pontuação 2
1 comentário:
Same problem. Mine will work for weeks before this starts again, but the only fix is to unplug for at least a few minutes - The longer the better it seems. Works fine and I still love it otherwise.
por
Adicionar um comentário
1 resposta
Mine has the very same issue, is there any known fix for this infinite phantom clicks? I really like my wakeup light for years now, it still looks like on day one.
Esta resposta foi útil?
Pontuação 0
2 comentários:
I solved it. you just need to solder the wires well
por
So you think it's a broken solder joint? Is it enough to heat the PCB? I am highly unskilled when it comes to microelectronics.
por
Adicionar a sua resposta
guglmobil será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 83
Ao todo: 879
