Ir para o conteúdo principal
Known as the ''PS2'', it is a sixth-generation video game console first released by Sony in Japan in March 2000. The United States saw it later in 2000 with the SCPH-30000. Repair of this device requires only common tools, but can get tricky.
199 Perguntas Visualizar todos
Why the hecc is my Playstation 2 doing this?
So I’m having issues with my Playstation 2. For some reason, my PlayStation 2 has weird graphical glitches (Screen flickers colors, goes in and out of signal). It was working perfectly fine before all of this. Is there a fix to this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Are you running with the original, or older cables? A lot of the time, this is cable or TV related. First thing I would try is a replacement cable - these are all over eBay and in many gaming stores. You will not be able to get an OEM Sony one these days (new, at least) but the 3rd party ones work well enough considering the resolution here. If that fails, hook it up to a different TV or if you can do so, try to find a projector to make testing this easier.
If neither works, it’s usually a connector or board issue - commonly bad capacitors.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
KOOL -AID será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 41
