Ir para o conteúdo principal
Can’t find replacement batteries anymore.
Is there a way to use a different battery? The connector is very unique and it makes it impossible to find a 3rd party replacement.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
You will probably need to purchase a new battery with the same voltage and amperage as your old one, then snip old battery wires and plug from old battery and solder and tape them on your new battery. Not as hard as it sounds. Not familiar with soldering wires? Im sure someone could do it for you in about 30 seconds.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Nathaniel Eltanya será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 106
