Powers on but no signal
Hi,
I have tried the guide about holding down the power button, got all the relevant beeps, but still there is no picture at all.
I was just wondering if anyone knew what the problem could be.
Thanks
Esta é uma boa pergunta?
Are you sure that your display (TV or w/e) and the output of the PS3 are compatible? IE, can you your TV only do 720p while the PS3 is trying to send a 1080p signal?
por Phillip Takahashi
Has it happen to you before? Is this PS3 new to you? Has it worked before?
por oldturkey03
Hi,
The tele is compatible as have played it on it before.
Also, no, it hasn't happened before and it has worked before
por Katy
Do you have a spare cable (HDMI?) to test? Might as well start at the cheap and easy fixes!
