Ir para o conteúdo principal
The third generation of the Apple iPad, released on March 16, 2012. Full 4G and Wi-Fi model repair guides. Repairs require heat and careful prying. Model numbers: A1416, A1430, and A1403.
310 Perguntas Visualizar todos
Logic Board Replacemnet - Touch ID Face ID Tied to the board?
I’m about to replace the Logicboard on a A1416 since the device is ‘Find My iPhone’ (I believe iCloud?) locked when I got it.
Is the Home Button, Touch ID, and FaceID (assuming it has the latter two) tied to the logicboard on this model? I can’t find anything on the topic.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
I guess I should've googled a bit more...
https://en.wikipedia.org/wiki/Touch_ID
This iPad 3rd Gen (released in 2012) is too old to have TouchID as it wasn't released until a year later on the iPhone 5s for phones, and didn't come to the iPads until 2014 with the iPad Air 2.
https://en.wikipedia.org/wiki/Face_ID#De...
Also too old for FaceID as well.
IE, the logic board can be replaced without the need for the home button that came with the donor board because it's so old. Home button will still work just fine.
Esta resposta foi útil?
Pontuação 0
Yes components with TouchID or FaceID are tied to that specific motherboard. So when you swap over the donor board make sure you transfer it’s associated home button to maintain TouchID.
Pontuação 0
2 comentários:
The Logicboard is one I got from Ebay.. I had assumed the device was too old to have those items tied to it's Logicboard, assuming it was along the lines of the iPhone 5 where it has them, but they're not tied to the board.
por
@crypticsoldier my bad I totally forgot you were working on an iPad 3, a model prior to TouchID so you can replace that button and it would work perfectly fine.
por
Adicionar a sua resposta
CrypticSoldier será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 100
