Navegue neste tópico para encontrar o local apropriado para este comentário. Em seguida, clique em “Anexar comentário a esta postagem” para movê-lo.
1 comentário:
Chances are your charger is either dysfunctional or doesnt provide enough power to the tablet, try isolating whats going on. Try a different charger if it works you know the OG one is either broken or insufficient.
This is probably not an issue with the tablet itself, this is probably the charger you’re using. Try using the charger provided by the manufacturer or use a different cable/adapter.
por Reagan
