Ir para o conteúdo principal
The Samsung Galaxy Tab A 10.1 S-Pen model: SM-P580 (WiFi), SM-P585 (3G,4G/LTE and WiFi) released in September 2016. It is a 10.1- inch tablet manufactured by Samsung Electronics and their new “A” series.
15 Perguntas Visualizar todos
Flashing screen and then dies
When the charge on my battery gets to about 45% the screen then freezes. After about 15 seconds it starts to flash and then dies. I am then unable to switch it back on.if I leave it for several hours, plug the charger in it comes up with 45% battery left and will then work, only to do it again when charge falls to 45% ?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi,
Does the tablet work OK when the charger is connected all the time?
If so maybe the battery is failing to maintain the load when its charge reaches 45%.
Try replacing the battery and check if that resolves the problem.
Here’s the iFixit Samsung Galaxy Tab A 10.1 S-Pen Battery Replacement guide that will help.
Replacement batteries are available online. Just search for EB-BT585ABA to find suppliers that suit you best
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Chris Ward será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 25
Duração total: 753
